Transmission Fitting
Old Jul 8, 2007 | 07:47 AM
ByuTrukr's Avatar
formerly ByuTrukFreak
Default Transmission Fitting
Does anyone know what size the connections for the transmission oil lines
are? Are they metric like everything else?
Old Jul 8, 2007 | 01:27 PM
blown3qtr's Avatar
The transmission oil lines are held into the fitting at the transmission w/ a metal clip. You can pop the clip out w/ an angled pick or a small poket screwdriver. The fitting itself unscrews from the trans w/ an 18mm wrench.
I hope this helps. I'm not quite sure what you are asking about. I can't think of one bolt on these trucks that is still standard. Everything is pretty much metric.
Old Jul 8, 2007 | 09:20 PM
ByuTrukr's Avatar
I'm changing the oil lines to stainless steel braided hose because I will use a B&M Supercooler. I will use AN fittings so I need an adapter that will screw into the transmission in place of the clip thing. I know it is a pipe thread but I'm not sure if it is metric. I don't even know if there is a metric pipe thread.
Old Jul 8, 2007 | 09:23 PM
nonnieselman's Avatar
This is what i did on my trans... but i cannot remember what threads they are.....
When i find out ill post up.....
Old Jul 8, 2007 | 09:44 PM
FLT's Avatar
FLT
FormerVendor
AN 1/4 male pipe to -6 Male.
Old Jul 8, 2007 | 09:52 PM
ByuTrukr's Avatar
Thanx Vince
Old Jul 8, 2007 | 10:01 PM
FLT's Avatar
FLT
FormerVendor
Your welcome. We do keep them in stock if you need them. Good luck with your project. Vince
Old Jul 8, 2007 | 10:12 PM
I thought it was a 14mm x 1.5?
Old Jul 8, 2007 | 10:43 PM
Yea thats what it was....
Vince is there anything you dont know about these Transmissions???
Old Jul 8, 2007 | 11:20 PM
1SlowHoe's Avatar
Destroyer of Transmissions
And you would have sold 2 to me last week had you answered your phone
