TRANSMISSION Code P0757 Today
Old Nov 19, 2007 | 10:30 AM
RedHot04's Avatar
Question TRANSMISSION Code P0757 Today
Hey guys,
set this code on the way to work. Check engine lite came on and I scanned it about 5 mins. later. Looked up the code : shift solenoid B stuck on. Now should I just reset the code and rock on, or will this be a long term problem? Found a table on GM service site WITH enable conditions but it doesn't give a solution. Any ideas? Thanks.
http://service.gm.com/gmspo/mode6/pd...2002trans9.pdf
Old Nov 19, 2007 | 02:01 PM
RedHot04's Avatar
hello... Vince, anyone?? Gotta drive home in a couple hours. Would like to be safe..
F' it heading home now. I'm just gonna clear it and hope for the best.
Old Nov 19, 2007 | 08:57 PM
performabuilt's Avatar
LS1TECH & Trucks Sponsor
PO757 could mean the solenoid is stuck on , However its also a comon code set with high stall converters, This may not happen imediatley when the converter is installed in fact it may never happen or happen randomnly , Ussually after you turn the truck off after it set this code everything returns to normal and it may be a while before it sets again. The fact that is dosent set again imediatly would be the indication that this is the real reason for the code. Nothing is actually wrong just the PCM became confused due to the RPM differential caused by the converter. If it comes on every time you drive I would replace the solenoid , If its random and happens every once in a while the sure cure would be to have your Tuner remove the test for the code.
Old Nov 19, 2007 | 10:33 PM
RedHot04's Avatar
Ahhh, thank you sir. Just a little worried because I do get a lot of lock/unlock in the 45-50 mph zone between 2-3 shift when lugging thru stop and go traffic. I know it needs a fine tune but I don't want any hard parts getting damaged as a result. Thanks for the translation, I can read all day about this stuff but interpretation is still a little difficult when it comes to the tranny department.
BTW it's the first time I've got the code...
Idryfly5
Sep 2, 2022 08:55 PM
Alco
Sep 4, 2015 04:08 PM
GreyChevy
Jul 7, 2015 08:57 PM
