Transgo shiftkit
Old Feb 16, 2005 | 02:51 PM
  #21
Occupational_Hazard's Avatar
Just curious about purpose of replacing the servos with corvette servos.
Old Feb 16, 2005 | 03:27 PM
  #22
My Transgo install alone with stock servos and one washer was too hard shifting. I took out all the washers and it is better. Light throttle shifts firm, partial throttle to full throttle shifts hard. I hope when I put a stall converter in in will soften the light amd part throttle shifts.
Old Feb 16, 2005 | 10:16 PM
  #23
Flyer's Avatar
gamedawg had some good advice ... drill the holes like he said, and don't use any of those washers. I would get a vette intermediate servo, and a billet overdrive servo if you tow a lot, if no towing, or minimal towing, I wouldn't worry with the overdrive servo. The servo's is what applies the band (what makes 2nd and 4th gear). The different servos have more fluid apply area, which creates a harder, firmer shift and a better holding power. If you move up to some serious power, like a blower, or spraying the **** out of it, step up to the billet intermediate servo too. The servos go in the side of the case just above the passenger catalytic converter. VERY easy to get to if you drop the Y-pipe.
The shift kit install isn't near as bad as it seems. Watch the video, think about it, and watch it a couple more times. I think I watched it 4 times before I actually did the install, and I felt confident with doing it afterwards.
BTW ... if you use the billet overdrive servo, there are some other valve body things that need to be done. If you go that route, I'll go into more detail then about them.
Old Feb 16, 2005 | 11:49 PM
  #24
Ok thanx you guys, I have never had any responses like this before. You guys give me more than enough information. I sure appreciate it guys. Flyer I will probably pm you about the servo question. that is when I get to that part.
SloSVO
Nov 22, 2020 07:34 PM
Wolftrk99
Dec 3, 2015 08:12 PM
jtphelps289
Sep 29, 2015 12:00 PM
EmmerichLSx
Sep 20, 2015 02:09 PM
lycominghunter
Aug 15, 2015 12:26 PM
