Transgo Shift Firmness...
Instaling the Transgo HD2 (4l80e) and was wondering what hole sizes to go with for the ABC holes. Options are:
A-4th
B-3rd
C-2nd
Hole Sizes
Average= 0.86
Softer= 0.76
Firm= 0.96
I am going to be running a Circle D Triple Disc Convertor with about 2800 stall and turbo. Want to make sure I am not on the harsh shifting side by opening them up too far. I am assuming the 1st to 2nd is the one I should be more worried about? Any Suggestions are welcomed because everything I have read is a little confusing as there is not a definitive write-up given my mods. Thank you!
A-4th
B-3rd
C-2nd
Hole Sizes
Average= 0.86
Softer= 0.76
Firm= 0.96
Last edited by Hivelocit; Aug 5, 2013 at 08:32 PM. Reason: Forgot to add which Trans
No other mods with the trans, and it's an 80e/lq4 matchup. I am just a lil worried how the 1-2 shift is gonna feel with the converter. Seeing what others have done with similar set-up and how they like it.
On my setup the builders went with firmest everything. It is definitely a positive shift, even a little jarring if I happen to be shifting through gears while in lockup, but it's not a bad engagement. 1-2 will pop the tires loose at WOT and all the other shifts are very crisp but get eaten by the converter.
I'm running stock line pressures FYI. When I first got the trans back I was still running my very high 60E pressure settings and the trans was literally chirping the tires on light throttle shifts.
