trans vs mileage vs mods
Old May 23, 2006 | 10:17 PM
i have been waiting on buying the shift kit because i know i need to get my line pressure back to stock before i stick it in there or stuff might start to break. it seems like my trans is lasting too long...if possible. every day i get more and more worried that its going to die and i am frequently not around my home. i have only had the mods in my sig for the longer of about 12000 miles. it towed our travel trailer about 5 times a year, 33footer, until dad gave me the truck when i got myh license so he could get a new one. maybe i should just start saviing and planning on the explosion
Old May 23, 2006 | 10:21 PM
TouchOfEvil04's Avatar
My stock unit would have probly been fine....but my builder said he was thinking i had a defective part from the factory.Manily because the input shafts almost never break and i broke it with under 300hp to the wheels...that just usally doesn't happen.
My only point to this is that i ahd the shift kit with one shim in and my line pressure upped for over 20k miles and no problems...i didn't blow it until i put a TB stall in it...I guess that was the last thing the bad part could handle.
Old May 23, 2006 | 10:29 PM
so when should i plan on having to have the trans replaced considering all the mods, uppe line pressure? i will also be installing a new cam, much more aggressive than my LS6. and the shift kit once i get line pressures reduced because i have read the wreck havoc on the 60e's
Old May 23, 2006 | 11:19 PM
Really depends on your power your making and how often/hard you drive it.
I had almost 300 to the wheels when mine went but it was from bad a oem part.
When we took the trans apart my gears and such were in perfect shape.No burning nothing so if your not terrible on it...it should last a decent bit.If not i did PM you with my tranny guys number...
Old May 23, 2006 | 11:25 PM
nah you did ill use it if i ever need it...im not too bad on it too much i figure im pretty close to 300 +/- some maybe i dunno. i was between 260 and 280 i think before cam wires and all trans mods. i dunno where ill be after the new cam, efans, LT's, and underdrive. probably knockin on the door of the closest transmission place
Old May 23, 2006 | 11:29 PM
After all that...yea it won't last to long i'm sure.Unless you only use the power that you add for races only heh...Then it might last a while.
Old May 23, 2006 | 11:36 PM
yea or just last through the 1/8th mile trap and coast me down to the 1320 on gthe first night out...
Old May 23, 2006 | 11:38 PM
Ethier way heh.
Oobray
Jun 13, 2022 03:38 AM
thewrx
Aug 12, 2015 08:28 PM
RoidedSS
Aug 11, 2015 11:51 AM
Ls3silverado
Jul 31, 2015 04:22 PM
black6spdz
Jul 16, 2015 01:32 AM
