Trans temp question..........
How accurate is the trans fluid temprature using the plug on the 4L60E??? The plug that everybody uses..........it's towards the top and roughly in the middle of the trans from front to back. I've heard that it isn't that accurate. I've heard that if you put a sender in the trans pan and one in the plug hole(as discribed as above), that the one in the plug will read higher than the one in the trans pan.....Is this true or have any of ya'll experienced this or performed any factual data by testing this theroy???
Any help will be greatly appreciated!!!! James |
My thoughts on this that the plug on the side of the trans is a pressure tap port. Since its plugged, fluid flow is a minimum and is seeing higher temperatures from heatsoak from the fluid and case itself.
Now a temp sender unit in the pan will show the temperature of the circulating fluid of the transmission. As all the lube fluid, valve exhausts, and piston exhausts all end up in the pan. |
get a bigger cooler and run the other two in series and be done with it somethings not right with the converter for it to be as hot as you are telling me mine never acted like yours is
I'm using the plug on the side of the 4L60E to monitor my trans temp. I know it's not accurate but at least it gives me an approximate temp. I've seen it up as high as 180* on hot summer days and barely even move on cold winter nights.
Now a temp sender unit in the pan will show the temperature of the circulating fluid of the transmission. As all the lube fluid, valve exhausts, and piston exhausts all end up in the pan. James |
Thank you gentlemen for all of ya'lls input!!!!! James |
I had mine in the pressure port. I now have mine in the pan. I saw no differences in temp between the two.
James |
Not to hijack but where is the sensor for the cluster tranny temp gauge?
Originally Posted by closet red neck
What are you talking about??? I'm talking about the trans temp on the trans fluid. Where is the best place to put the sender for an accurate temprature for the trans fluid?
James Placing the sender in the pan, allows the temperature of the circulating fluid to be measured. Fluid coming from the transmission cooler goes straight to the lubrication, and consequently cooling then goes right to the pan. As for fitting it into the pan, i cant see how it would be easy with the stock pan as its thin. Now my TCI deep pan actually has a sender hole pre-tapped. |
