Trans output shaft and pinion spline counts and u-joint??
Old Oct 18, 2007 | 06:21 AM
tdrumm's Avatar
Default Trans output shaft and pinion spline counts and u-joint??
What is the spline count on a 4L65E output shaft and pinion gear spline count on a 10 bolt?
What series u-joints are stock on a 1/2 ton? 1310? 1330?
Also, does the part of the driveshaft that is attached to the diff (don't know it's real name) need to be changed when upgrading to stronger u-joints? And can that part be changed without tearing down the entire rear end (again)?
Old Oct 19, 2007 | 07:27 AM
FLT's Avatar
FLT
FormerVendor
27 Spline one the trans. Not sure about the other stuff. Vince
Old Oct 19, 2007 | 07:08 PM
IslandTahoe's Avatar
Try looking at a '3r' series u-joint (inner lock). This is what I saw for my Tahoe and if I recall the table in the book at the driveline shop.......same as the 1/2 ton truck.
chopperloco
Jul 10, 2016 10:45 PM
Abuckeye
Aug 19, 2015 06:11 PM
GMCtrk
38
Aug 9, 2015 08:50 PM
Ketis
Jul 23, 2015 12:37 PM
alex226
Jul 16, 2015 10:55 AM
