trans fluid question
from what i gather synthetic fluid is not recommended for built tranies. but is castrol atf ok? is says for older transmissions and is good dexronIII. but not for use in cars requiring dexron VI. is this ok to use?
well the castrol atf was on sell and 3.50 less than the mobile VI. if thats what i need so be it but if not then don't wanna waste my money. i had royal purple in my old tranny and it still failed.
GM Dexron-VI is formulated to be compatible with all seals, gaskets, and friction materials that Dexron-III. It is a direct replacement for all GM/Hyrda-Matic transmissions. Oddly enough, you can even mix III and VI.
