Trans Cooler mounted...need help connecting
Old 12-28-2005, 12:20 AM
14 Second Truck Club
Default Trans Cooler mounted...need help connecting
I got the perma-cool transmission cooler mounted tonight. I was gonna hook it up, but ran into a couple of problems. First, the nuts on the radiator that connect to the metal tubing wouldn't budge. Is there a trick to getting these off? Also, what size wrench do you use?
When I do get all that figured out, does the top metal tubing connect to the top tubing of the trans cooler and the bottom metal tubing to the bottom tubing of the trans cooler?
Should I put any tranny fluid in the tubing or cooler to avoid air in the lines or will it work itself out?
Check out what it looks like----> Go to the link in my sig and click on My Albums (picture of my ported TB) and go to the last 3 pictures. Let me know what you think.
Old 12-28-2005, 01:10 AM
High on diesel fumes
thunder550's Avatar
No wrench needed to get the lines out of the radiator. There's a plastic cover that you can pull back, then a C-clip underneath that comes off, then you just pull and the line should come out.
Old 12-28-2005, 12:15 PM
Worked like a charm, Thanks! I spent about 15 minutes last night struggling with a wrench
I connected everything and no leaks, the tranny seems a little firmer especially the 1-2 at wot. I didn't think I'd be able to tell a difference at all.
Old 12-28-2005, 02:25 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Cooler fluid atleast in my trans like right after I start it up it will bark the rear tires on the 1-2 shift but once its heated up it wont do it anymore. Congrats on the install it will make your trans alot happier.
GRRR65GTO
08-17-2015 11:33 PM
1slwgto
08-16-2015 06:40 PM
zaathur151
08-12-2015 06:32 PM
Ls3silverado
07-31-2015 04:22 PM
ferrellrooster
07-17-2015 07:07 AM
Quick Reply: Trans Cooler mounted...need help connecting
