trans cooler lines
Old Jan 2, 2007 | 08:18 PM
silver-mod-o's Avatar
Hunt&Fisherator
Default trans cooler lines
I have noticed I have one leaking right up near the a/c compressor.... has anyone had this happen? where can I get another one??? can I have hoses made up so I can route them where I want? I know these have been tugged on a bit doing so many tranny swaps maybe one just got pushed up against something and rubbed a hole in it. I havent seen exactly where the drip is coming from yet but I have it tracked pretty close.
The truck goes up on the lift again tomorrow I guess
Old Jan 2, 2007 | 08:27 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Pull 'em and make some -6 AN lines imo.
Old Jan 2, 2007 | 08:32 PM
Hunt&Fisherator
I thought about it... how would I do the ends where it clips into the trans??? have them made onto the hose somehow? there's a custom hose and fitting place here in town and they did a ton of **** for my buddy's mustang's nitrous system. they were the first place I thought of when I saw the hole. it leaks a qt or 2 a day right now depending on how much/hard I drive it.
Old Jan 2, 2007 | 09:07 PM
getchusum99's Avatar
why not cut the two lines that goes into the radiator and tie into them there with new hoese, just use a fee hose clamps, that what i did, then i ditched the stock aftermarket cooler and the one that runs into the radiator and put a huge rv cooler in front of the ac condenser, no problems yet.
Old Jan 2, 2007 | 09:50 PM
Bill Reid's Avatar
Call Chuck at FLT... I did... and will be pulling my entire tranny coolant line circuit out, bypassing the radiator, and going with a big cooler... using all -6AN hardware. I am not necessarily suggesting you bypass the radiator because in colder climate areas of the country the radiator actually warms the transmission to operating temps. Down here in AZ... I don't really have to worry about it.
Bill
Old Jan 3, 2007 | 08:11 AM
Hunt&Fisherator
I have my cooler connected with hose and clamps but I didnt think it would be strong enough to run for ALL the cooler lines. I'll have to call Vince and Chuck and get their take on it.
Old Jan 3, 2007 | 09:00 AM
ScojoDak's Avatar
Silver-mod-o, get you some of the hardline to braided line adaptors from Jegs. I use them and they work great.
Old Jan 3, 2007 | 10:11 AM
TG02Z71's Avatar
Be careful bypassing the radiator all together if you live somewhere that gets cold. It actually helps your trans get up to temp when its really cold out.
You probably already knew this but just wanted to bring it to light.
Old Jan 3, 2007 | 11:42 AM
Hunt&Fisherator
yeah, I dont plan on bypassing it. I'm just going to replace the existing hard lines with some hi-pressure hose with good fittings... it should work out great and I can get them long enough to re-route them away from the starter and everything else hot in there... I am thinking about running them over the frame to the outside of the frame rail and up to the front of the truck that way.
Old Jan 3, 2007 | 12:35 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Russell-brand hose ends... they work wonders!
