trans cooler help
Old Jul 18, 2007 | 11:48 PM
way2much_01's Avatar
Unhappy
it's still under warrenty do you think they will cover it... and does anyone know how many quarts of trans fluid these 4L60e hold? by the way it moves but not like it used to it's like once it gets up to 2-3000 rpm it just revs and the rpm's goes higher
Old Jul 19, 2007 | 07:24 AM
2001si3rr@'s Avatar
If you have cut tranny cooler lines you might have a problem with warranty work. But it never hurts to ask, they might work on it. Sounds like your tranny is slipping, are you sure you added enough fluid?
Old Jul 19, 2007 | 08:04 AM
no im not I only put 4 quarts I'mmaadd more
Old Jul 19, 2007 | 08:28 AM
2001si3rr@'s Avatar
Start your truck and let it idle to get up to normal temp. Check your tranny fluid level with it in park, add fluid if you need to. With brake applied move shifter slowly through the gears all the way down to first. Making sure you feel each engagement of that particular gear. Then starting from first move it through each gear again and stop in park, check your fluid level again. You may have to repeat this process a couple of time to get the level right. Once you get a good reading of the fluid level button it all up and take it around the block, drive slow to feel each gear as it shifts. Pull over and check the fluid level, if that is good get it on the highway and see how that goes.
Old Jul 19, 2007 | 08:30 AM
2001si3rr@'s Avatar
I'm no tranny expert, but this is the process I use when I changed my torque converter.
Old Jul 19, 2007 | 08:12 PM
thanks for the help I got it back working it held 6 1/2 quarts so I'm guessing it wasn't all the way dry thats a good thing... it's not really slippin or nothing it still picks up speed and everthing no noticible damage I'm still scared though...
Old Jul 20, 2007 | 06:53 AM
2001si3rr@'s Avatar
Good deal, glads to hear it's working. I'm sure you prolly knocked some of the life off of it, but it'll give you reason to buy an FLT later on!!!!!
Old Jul 20, 2007 | 08:05 AM
OnyxSilveradoSS's Avatar
i did the same, put the cooler on and b/c I was pulling on the lines the one on the trans popped off on the freeway and dumped all my fluid and the dealer replaced it.
Old Jul 20, 2007 | 12:33 PM
Yeah I kno I think my next move is a shift kit
flatblack83
Jan 3, 2026 07:10 PM
MA$TER_E
Sep 9, 2015 03:14 PM
Cowboy Tom
Sep 5, 2015 04:29 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
ferrellrooster
Jul 17, 2015 07:07 AM
