trans cooler help
Old Jul 17, 2007 | 12:40 AM
way2much_01's Avatar
Default trans cooler help
I gotta 05 avalanche and I'm tring to install this trans cooler I need to know what direction of flow the trans fluid is coming from the trans and going to the radiator theres two lines one going to the radiator one on top and one on the bottom I need to know the inlet have anyone installed one before help me out
Old Jul 17, 2007 | 12:43 AM
RoosterMcCandles's Avatar
I am lying in bed but if no one answers, I'll check mine in the morning and let you know...
Old Jul 17, 2007 | 01:21 AM
StrokerAce03's Avatar
Here you go; its the install with pics. The pics are an f-body but the setup is the same; its what I went by
http://www.bfranker.badz28.com/94z/trannycooler.htm
Old Jul 17, 2007 | 10:47 AM
ReSpAwN DeMoN's Avatar
I don't quite remember exactly. I think it was the bottom one was the return to the tranny.
Simply cut that line and have someone crank the vehicle. If you fluid spits out you know thats your line.
Old Jul 18, 2007 | 11:39 AM
budhayes3's Avatar
PT's Slowest Truck
The top line in the radiator is the return, tap into that one.
Old Jul 18, 2007 | 07:32 PM
thanks for the help the top on is the return to the tranny... I installed the cooler last night I'm driving today and I'm losing power so I pull over and what do you know a hose busted... I think it maybe have from using a fuel line I got from atuozone cuz I didn't have enough hose that came with it so I lost all my tranny fluid... do anyone think I may have some tranny damage now I drove on it about 6 miles?
Old Jul 18, 2007 | 07:36 PM
oh I forgot to ask am I supposed to tap in the line going to the tranny or from the tranny I tapped in the one thats going from the tranny
Old Jul 18, 2007 | 07:59 PM
2001si3rr@'s Avatar
Pull the top tranny line on your radiator connect that to your tranny cooler, this will be your return line to the tranny. Then connect your other line on your tranny cooler back into the top of the radiator, this will be your pressure or input from the radiator to the tranny cooler. That's how they are from the factory. Basically the radiator will heat the fluid up to temp and the tranny cooler will cool it down a bit before returning it to the tranny.
Old Jul 18, 2007 | 09:23 PM
do you think I caused any damage?
Old Jul 18, 2007 | 10:48 PM
truckmann's Avatar
One good way to tell. Fill it back up and see if it still moves. Unfortunately I would bet that even if it does still move that some damage was done and you have shortened the life of your tranny. So pray that it still works and start putting money in the new tranny fund now.
