Tranny & Stall Gurus Come in...
Old 01-25-2012, 01:11 PM
sprayedenali's Avatar
Ya, those calculators don't take into account TC slip and what not. That mph is as if everything was 100% locked up
Old 01-25-2012, 01:22 PM
Swerve7rpm2000's Avatar
Yeah TH400 convertors dont lock but slippage should be minimal once stall speed is reached right?
Old 01-25-2012, 01:24 PM
13 Second Truck Club
LS1FREEK's Avatar
I would definitely say its your converter, it sounds like your pushing through it. What brand, diameter size and speed is it?
Old 01-25-2012, 01:29 PM
LS1FREEK's Avatar
To go 160mph in the 1/4 you would need atleast 1300 whp.
I could be wrong, but I don't think he's complaining about what speed he's running, rather the rpm he's hitting. I think he definitely shouldn't be hitting 6500 rpm @ 130 mph, with the tire size/gear ratio combo he has....
Old 01-25-2012, 01:43 PM
Its a Midwest either 9.5 or 10" and id assume stall speed is anywhere from 3400-4000 i know thats a huge range but its real loose, but like i said i can just blip the throttle and it runs up to 3200-3400 before any movement
Old 01-29-2012, 08:15 AM
Hunt&Fisherator
silver-mod-o's Avatar
I'd tighten up the convertor a bit to increase the overall efficiency. What's killing you is your relatively low compression IMO. With either a little more compression or more boost you'd go a good bit faster and quicker with about a 3000 converter.
For the record, I've always liked your truck a lot
Old 01-29-2012, 11:43 AM
Just what i was thinking, will prolly be my next option to buying a new converter, thanks alot ive got alot of time in this big ole gurl lol!
Old 01-29-2012, 12:19 PM
I have a gauge for that
Atomic's Avatar
Those online calculators probably dont give you the option of selecting a drag coefficient and probably just assume a relatively low one since trucks arent meant to go fast
Old 01-29-2012, 12:36 PM
11 Second Club
Phantom's Avatar
Pro torque outbid new York seems to be the hot ticket right now in torque converters. Settin records all over the place
Old 01-29-2012, 10:35 PM
Thanks for the responses guys, ima bump the rev limiter up to 7200 and shift at 7k and end up on 20#'s or so by the end of the track on the next trip to see what it does with the extra power first.... I did do a little bit more testing with it the other night see if this sounds right... im going about 40 mph shift it in first no change at all as far as mph or engine load and i blip the throttle hard and it ran up to 4k immideatly before it tried to move... so in my eyes this would be every bit of a 4k stall
Quick Reply: Tranny & Stall Gurus Come in...
