tranny pan gasket
Old Apr 18, 2005 | 11:18 AM
moregrip's Avatar
what a rush!
Default tranny pan gasket
what did you use? GM?
Old Apr 18, 2005 | 11:41 AM
Kano's Avatar
cork
from autozone
comes with the filter
Old Apr 18, 2005 | 12:01 PM
oxidizr's Avatar
Moderator / Sponsor
Most Shift kits include a gasket... I use sealant only on cast and gaskets only with stamped pans.
Old Apr 18, 2005 | 12:41 PM
moregrip's Avatar
what a rush!
Wow, interesting, I got the Hughes Deep Pan. Do you use the Black Sealant?
Old Apr 18, 2005 | 01:16 PM
slowec's Avatar
Any sealant that ends up in that pan could cause u trouble.I would use the correct gasket. G.M. Just my .02
Old Apr 18, 2005 | 08:11 PM
SnakeOiler's Avatar
I use factory gasket, no sealant. Comes with filter. No problems.
Old Apr 18, 2005 | 08:26 PM
budhayes3's Avatar
PT's Slowest Truck
Factory gasket here too...
Old Apr 19, 2005 | 12:55 AM
A new one came with the trans filter. I didn't use it though, the stock one was perfectly fine so I just reused it.
Old Apr 19, 2005 | 09:32 AM
oxidizr's Avatar
Moderator / Sponsor
I cant see how as the filter screen is much smaller than would allow any material to pass ant the area around the screen would require a substantial blockage to cause any fuild deprivation.
I have built about a dozen or so trannmissions with B&M deep pans with no problems in this matter ... I guess it is just attention to detail. Anyone one can screw up anything if enough care is not taken.
Old Apr 19, 2005 | 11:40 AM
Mort's Avatar
The stock GM gasket on a 4L80E is very good quality and is reusable. I would just reuse the stock gasket.
