tranny noise help
Old Jan 21, 2010 | 09:38 PM
greenturtle05's Avatar
Default tranny noise help
after installing my stall now i have a tap/ light knocking noise coming from the trans. what could it be?
Old Jan 21, 2010 | 09:40 PM
Black'Rado's Avatar
taking a guess that could maybe be a cracked flexplate????
Old Jan 21, 2010 | 10:16 PM
leonpiper69's Avatar
or maybe you didnt tighten the converter bolts as tight as you thought?
personally, i like to thread all 3 most of the way then go around and fully tighten them. i have had them seem tight because the hole werent lined up perfectly and you think its nice and tight but after its running the bolts moved a little and loosened up.
Old Jan 22, 2010 | 06:27 AM
thanks i'll check to make sure that they are all tight. i tightened them pretty tight though
Old Jan 24, 2010 | 07:30 PM
found out what the problem was. the dust cover on the driver side was slightly off. shifted it over and noise is gone. driving the truck now is more fun than ever, but i think i may want a larger stall.
Wolftrk99
Dec 3, 2015 08:12 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
Infernohoe
48
Oct 2, 2015 10:25 PM
Velocity1
Oct 2, 2015 08:01 AM
sTNT971
Sep 26, 2015 06:27 AM
