Tranny Help! Again!
Old Jul 8, 2008 | 07:07 AM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Originally Posted by 02Denali6L
I didn't plan for the tranny shop to build it this time. I want them to send it off. I just don't want it "fixed" again.
What kind of clutches did they use? I've had no issues with Red Eagles. If I remember correctly, FLT uses BW's HE clutches. I wouldn't go less than an L5 with vehicle weight and power. White1's gone over 3 years with that in a 6.0L-powered Z71... and beats the snot out of it.
Old Jul 8, 2008 | 09:48 PM
02Denali6L's Avatar
Here's the verdict, 2 problems...
#1 Burned 3-4 clutch pack. And #2 this is the second time the input drum has broken around the collar of the input shaft. This one was a cryo treated drum. The local tranny shop thinks it may have cracked and caused low line pressure which burned up the 3-4 clutch pack before it broke...???
Could this cause the 3-4 pack to burnout while cruising down the interstate? I justwant to correct the problem before it is together again, FLT5 this time. I know this may fix it but is there something else in the tune to look for?
Old Jul 8, 2008 | 10:41 PM
TurboGibbs's Avatar
It sounds like a softer shift is a must.
Old Jul 9, 2008 | 11:04 AM
02Denali6L's Avatar
This one mis-shift is my concern after first retune with the header install. It hit the revlimiter and refused to shift... The computer seemed to be hung up or a shift solenoid??? this was the 2-3 shift. Or it just may have slipped like there was no gear when it did shift into 3rd. It did this again when it broke this time... The 2-3 shift occurred at light throttle about 2500rpm and then free spun with no gears working...
Old Jul 9, 2008 | 07:45 PM
02Denali6L's Avatar
FLT5 on the way... A big Thanks to Andy and Chuck
Old Jul 9, 2008 | 07:50 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Dude!! Congrats on one of the best purchases nobody will ever look at or hear. I feel for the transmission builders like Vince and Chuck who work so hard to create a fine piece of machinery only to have it shoved up under a truck to never be seen again.
Wolftrk99
Dec 3, 2015 08:12 PM
sTNT971
Sep 26, 2015 06:27 AM
racedad70
Sep 16, 2015 01:51 PM
JordanH
Sep 12, 2015 12:02 AM
mayko
Sep 7, 2015 12:24 PM
