Tranny breather lines?
Old 09-08-2008, 07:04 PM
Senior Member
Country Boy's Avatar
Default Tranny breather lines?
Whats the breather line routing on an auto tranny? I have a breather line that runs off the top of the tranny to a T... one goes to a one way breather fitting (the little white plastic fitting in the hose) and the other goes to an open end. I know its supposed to be hooked to something since it wouldnt just be an open end hose... any ideas? Its a 4wd too.
Old 09-08-2008, 07:07 PM
Baltimore Whore
Mangled03gmc's Avatar
Mine is the same way. After I did my engine swap that bracket didn't get hooked back up. I cut it odd short, fastend it to the top of the trans, left the other one where it was.. It is a vent of some sort..
John
Old 09-08-2008, 07:59 PM
High on diesel fumes
thunder550's Avatar
Do you have a breather hooked up to the top of your transfer case? That might be it....I'm not real clear on your description of where the T is and where the two sides of the T go to.
Old 09-08-2008, 08:22 PM
KySilverado's Avatar
Vent tube at top of transmission and another vent tube on the transfer case.
Old 09-08-2008, 08:42 PM
Senior Member
Yeah, I figured it out. One is for the transfer case which has its own seperate breather line and theres one line that comes out of the top of the tranny to a Y and one end goes to a breather fitting and the other end just stay open for a puke tube incase the tranny needs to puke fluid.
Old 02-20-2015, 09:20 AM
Mike1992's Avatar
Bringing this back, my truck is 2wd and I've got the same thing., Breather out of the trans goes to a T and one end is vented open to nothing and the other to a white cap vent. Am I missing something?
Old 02-20-2015, 09:54 AM
03sierraslt's Avatar
No, if you overfill it then it will blow out that vent.
Old 02-20-2015, 10:14 AM
DrX
DrX's Avatar
White cap goes up high for venting and as stated, overflow goes rearward, low for puking. Don't want trans fluid spraying into the engine compartment.
Old 02-20-2015, 10:33 AM
02 w/ lowest mileage 2800
blown02408's Avatar
Don't want it all over the back of your truck or on the track either if you go to the drag strip, put a catch can on it!
Old 02-20-2015, 03:18 PM
Mike1992's Avatar
Awesome, thanks guys
BROKE-aSS-BLAZER
10-13-2017 03:50 PM
Wolftrk99
12-03-2015 08:12 PM
lukn4trbl355
10-21-2015 11:19 PM
sTNT971
09-26-2015 06:27 AM
lxcoupe
09-25-2015 12:36 PM
Quick Reply: Tranny breather lines?
