traction at the strip? who has it and how
Old Dec 15, 2005 | 02:23 PM
zippy's Avatar
I agree with TJ and Mark. Cal-Trac's should do the trick, but unless i'm missing something in your mod list, you don't need a big slick...you need suspension work.
Old Dec 15, 2005 | 05:16 PM
quicksilverado's Avatar
Forget the et streets. They are a waste if your making any kind of power. Grind your rotors and get some M/T 15x28x10.5 drag radials. Look what the outlaw cars are doing with these tires. I can do 1.6x all day at the track. When I up the rpms on the 2-step I believe I can get into the 1.5s My suspension is bone stock other than Edelbrock IAS shock.
Old Dec 15, 2005 | 06:53 PM
goshawk23's Avatar
Truck addict
i do have a 2/4 drop that bigkid and i are gonna install here in a few days. with that in mind, i will go ahead and pull the front sway bar and ride like that. i guess instead of spending the money on wheels and tires i will go ahead and make the necessary adjustments to the suspension and go from there.
thanks for all the ideas and tips and such.
Old Feb 21, 2008 | 01:56 AM
bluecajun5.3's Avatar
11 Second Truck Club
back from the dead.
Originally Posted by blacksheep
The problem is easily fixed. Ditch the front sway bar, get some Cal-tracs, Comp. Eng. front drag shocks, use wore out rear shocks, and pull the bottom leaf spring out of the spring pack. On 28x11.5x16 ET Streets my truck went 1.48 60' on the exact same set up with 500rwhp on motor.
^sheep, at that time was the truck lowered any?
sounds like some good info and results from everyone in here.
Old Feb 21, 2008 | 07:30 AM
Red03SilSS's Avatar
AWD helps ALOT!
Old Feb 28, 2008 | 02:13 PM
StrokerAce03's Avatar
Goshawk was banned?
Vortec350ss
Jan 12, 2016 10:36 PM
bearden86
26
Nov 15, 2015 03:58 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
Slammed silverado
Sep 28, 2015 06:14 PM
whitelazer
Sep 22, 2015 09:38 PM
