Traction Bars
Old Mar 7, 2005 | 08:02 PM
1BADDASSBOWTIE's Avatar
13 Second Truck Club
Default Traction Bars
What traction bars is everyone using? I am thinking about just going with the 30" universal lakewoods. The "slapper bar" type. Would they be good enough or should I go with a link setup, I dont really want to weld, so thats why I was leaning toward the lakewoods. Any opinions are appreciated.....
Old Mar 7, 2005 | 09:33 PM
BMDMAX's Avatar
Cal-Tracs all the way.....
Old Mar 7, 2005 | 09:37 PM
joesilver01's Avatar
Just my opinion and laws of physics but I would defenitely go with a 4-link over traction bars on leafs. 4-link will have dramatic handling and traction characteristics. If you wanna go for that? probably cost a little more and be more work but I think it would be worth it for sure.
Old Mar 7, 2005 | 10:44 PM
Where is the best place to get them? And have any pics of your setup?
Old Mar 7, 2005 | 10:53 PM
Not Sure?? I am having mine completely fabricated because I am running complete air ride suspension. Wish I had some pics to show everyone but I am broke with all the money goin into my truck. No money for a digital camera!!
U could try Air Ride Technologies just for the 4-link has pretty good stuff. They sell mostly air ride stuff but have good parallel 4-link kit you can buy by itself.
Old Mar 8, 2005 | 12:30 AM
FILE's Avatar
http://www.calvertracing.com/
Old Mar 8, 2005 | 09:22 AM
BMDMAX's Avatar
I got mine from www.kennedydiesel.com but there are plenty of places to get them.
Here are some photos of them on the truck but I don't have any specific shots of them.
They have worked pretty well on my truck even with the heavy 3/4 ton springs. I can tow, use the truck for heavy work and as a daily driver and still lay down 1.8 60' times on slicks.
Old Mar 8, 2005 | 09:44 AM
quicksilverado's Avatar
How difficult is it to install the cal-tracs?
Old Mar 8, 2005 | 10:09 AM
BMDMAX's Avatar
It depends on how handy you are. I don't know how different the install would be on a 1/2 ton but the install was not too bad on the 3/4. It took me a solid afternoons worth of work. The hardest part on my truck was clearing the front spring eye bolt from the fuel tank and getting the front bushings out. I drilled out the rubber bushings and then hit them with an air chisel to pop out the sleeves.
Pressing in the new aluminum bushings went pretty easy with a handheld screw press. The rest is fairly easy, just take your time and support everything well as you work.
Old Mar 8, 2005 | 10:13 AM
14 Second Truck Club
Those universal lakewoods would not work well at all. You would proabably control wheel hop some, but they would put a lot of stress on the spring. Dont they make a slide-a-link for these trucks? Similar to a cal-trac, but they adjust different and I heard they are a little better.
