towing with a converter
Old Mar 17, 2005 | 10:09 PM
Default towing with a converter
Is it true that you cant tow much if at all with a converter? I have the 5.3 and will be installing a 3k stall. May be looking at a race car in the future. thanx.
Old Mar 17, 2005 | 10:18 PM
desTRUCKtive's Avatar
Generally you really dont want to tow anything major with a converter. You can but IMO you really should avoid it if you can. Especially with a 3K stall. With a 3K you are already going to generate more heat for your tranny, and towing a load will be even greater heat on the tranny. With a 3K you need tranny cooler, and if you are going to tow with it you should maybe install an external fan with it as well.
Old Mar 17, 2005 | 10:37 PM
Ok thanx I dont really plan on towing at all really. If I every do get a car I live just donw the road from the track so I could drive the car downt here. (if possable) If not its like 1.2 miles donw the road so. I was just wondering if I could pull anything with my stall. So the main concern is temp. huh.
Old Mar 17, 2005 | 10:53 PM
Yeah, high temps will for sure cut down in the life of the tranny, and especially with these 60E. These trucks more or less have pretty high torque peaks around 3500 RPM stock, this is where most of the torque is. So if you put a 3K stall stall you are not going to have a problem towing anything since it is going to shoot your powerband within that range. But also keep in mind that everything else is spinning faster and generating more heat and with a load that is going to increase as well. Once its gets locked up and you are on the highway you should be fine. But if you are going to tow something in the middle of LA with stop and go traffic. That is really going to kill you. I am going to get a bigger tranny cooler for mine and also out an external fan on it becuase I live in the Desert and in the summer temps are greater than 100 most of july and august.
Old Mar 17, 2005 | 11:02 PM
Ok well thats cool with me. Also thats some information that I didnt know about. I do have a B&M 24,000 on it right now, I thought about putting one more of those on it any ways just because but not sure yet. The temps around here are the same way. 100s in the summer.
Oobray
Jun 13, 2022 03:38 AM
2500ZL1
Jan 25, 2016 06:30 AM
Fast86z
Aug 23, 2015 12:35 AM
ZONES89RS
Jul 22, 2015 12:35 PM
