Tow/Hual mode while racing!
Old Jun 19, 2006 | 01:11 PM
Beastofa327's Avatar
Default Tow/Hual mode while racing!
Has any one used this for racing. I've never use it till this past weekend to haul dirt and thats when I thought about it. the shife points are higher but I don't know at what RPM max tourqe is made for each gear. I never had my truck Dynoed yet!
Old Jun 19, 2006 | 01:34 PM
simple02's Avatar
word, it just holds the gears longer...i have noticed its a bit faster when i punch it when its in tow/haul mode...
Old Jun 19, 2006 | 01:43 PM
Nick™'s Avatar
tow haul manipulates the transmissions electronic controls, it commands the PCM to reference different tables in the tune for shift patterns and firmness
Old Jun 19, 2006 | 01:55 PM
Yelo's Avatar
It's just a trans modifier.....we've ALL looked a this at one point or another to see if it could be made into a Tow/Haul *** mode
Old Jun 19, 2006 | 02:03 PM
silver-mod-o's Avatar
Hunt&Fisherator
does it bump line pressure at all? it feels firmer aside from just different shift points. mine is tuned differently wnyway so I know it wouldnt apply but what abou the stock tune?
Old Jun 19, 2006 | 02:06 PM
thunder550's Avatar
High on diesel fumes
Yes it does bump the pressure a little
Old Jun 19, 2006 | 02:45 PM
04Denali's Avatar
I get better times at the track with tow haul mode. I have my shift points set a little hight in tow mode. Shift firmness is the same because I have a vacuum modulator
Old Jun 19, 2006 | 02:50 PM
04Denali's Avatar
Thunder550
I was noticing your 1/4 times in your sig. I am a .10 faster but 5 mph slower
Old Jun 19, 2006 | 03:20 PM
Superado's Avatar
11 Second Truck Club
The following article discusses setting tow/haul mode to tow/haul *** mode using hp tuners:
http://gmhightechperformance.com/tec...uck/index.html
Old Jun 19, 2006 | 04:09 PM
thunder550's Avatar
Originally Posted by 2004Denali
Thunder550
What engine and cam are you running? I have noticed that people running the Radix'ed 5.3/4L60E or a 6.0/4L60E combo seem to trap a little better but have slower speeds. My 5.3/4L60E combo was a 13.57@99, 1.92 60'.
I think it's cause of the gear ratios. The 3.06 1st gear in the 4L60E gets you out of the hole faster, but the 1-2 shift generally makes the trucks fall on their faces. I think 2nd gear in the 4L60 is 1.75. Big drop from 3.06 to 1.75. Plus, you are crossing the traps well into 3rd gear.
The 4L80E has a 2.48 1st gear which sucks getting you out of the hole, but the drop from 2.48 1st gear to a 1.48 2nd gear is much less dramatic and keeps me in the meaty part of the power band. I cross the traps right at the top end of 2nd gear.
