torsion bar keys
Old Feb 23, 2006 | 04:20 PM
ramair383ci's Avatar
Default torsion bar keys
I just wanted to know do the torsion bar keys ever come off the torsion bolts like when the supspension hangs all the way on a big dip or bump? Do they ever move in the opposite direction of the bolt? The reason I ask is because now that I have maxed out my torsion bolt or torsion key by adding a longer bolt the truck is bouncey inside is there any way of correcting this? Should I just get the Ford keys, will this correct the bounceyness and give the 2 to 3 inch lift in the front?
Old Feb 23, 2006 | 05:15 PM
our trucks are built to ride on the front bump stops, it cushions the ride. you are probably high off them now thats why its bumpy, you can really only get about 1.5" lift with the keys. without a bouncy ride, i did the same to my dads 2500hd
Old Feb 23, 2006 | 06:12 PM
The thing is that i welded new plates because i was under the same impression it helped some what but I guess I have to get used to it.
Old Feb 23, 2006 | 06:36 PM
02sierraz71_5.3's Avatar
ford keys will get rid off the bounce while leveling the front with the stock rear
Old Feb 24, 2006 | 07:18 AM
Thats what I wanted to hear. I realy don't want my truck level I just want the front end higher so it can realy look like a Z71. I like the stock rake the truck has so I got some 2-1/2" Add-A-Leaf. So even after I lift the front it will still have the same stanz.
Old Feb 24, 2006 | 05:18 PM
Mort's Avatar
Cool
Longer shocks may help as well. You are probably past the effective operating range of the front shocks. Look for some good shocks for a lifted vehicle as I have read that can go a long way to reducing the sringy feeling in the front as well. Ford keys for the front end are a good idea as well as you are well past the designed adjustment range of the stock keys.
dsbodley
Nov 14, 2015 09:46 PM
cheyenne383
Nov 13, 2015 09:24 AM
Alco
Oct 4, 2015 06:58 AM
carid
Oct 1, 2015 09:22 AM
WICK3DxGATA
Sep 24, 2015 06:56 PM
