Torsion bar isolators
Old May 19, 2013 | 10:46 AM
axekick's Avatar
Default Torsion bar isolators
My torsion bar crossmember looks all cocked like the isolators are worn out. It's a Tahoe so they are welded to the frame and the rubber is bonded to the bracket so there is really no easy way to replace them. Anyone ever run into this? What if I weld them solid so that the crossmember isn't isolated with the rubber bushings? Think it would cause problems?
Old May 19, 2013 | 11:33 AM
Koots's Avatar
I'm not sure how much different the Tahoe is, but on the trucks, you need to grind 4 rivets off of each mount, from the outside of the frame. They are replaced with bolts and nuts.
Old May 19, 2013 | 11:40 AM
axekick's Avatar
The tahoe is different. The frame is fully boxed. There aren't any rivets. It looks like the same part but it's completely welded on.
Old Jun 21, 2013 | 08:22 PM
axekick's Avatar
We welded new isolators on and they were just as flexible as the original ones so that was a waste of time and effort. But then, since my dad works at a precision sheet metal shop, he got some parts cut on the laser.
Here's how the go on:
It stiffenned it right up. It feels solid now. Now I'll just have to see if it rides any differently or if it causes any unexpected problems.
Attached Thumbnails Torsion bar isolators-washers.jpg   Torsion bar isolators-washers-installed.jpg
dantheman1540
Nov 1, 2015 02:59 AM
turbo6c3
Oct 5, 2015 06:11 PM
Alco
Oct 4, 2015 06:58 AM
carid
Oct 1, 2015 09:22 AM
WICK3DxGATA
Sep 24, 2015 06:56 PM
