Torque Specs: U-Joint strap bolts?
Old Jan 14, 2015 | 02:57 PM
CashDudeHomie's Avatar
Thank you for posting that correction. There are a lot of people out there who might have actually taken that wrong figure and used it. I googled for the U joint bolt torque and this was the first thread that came up.
Old Jan 14, 2015 | 06:44 PM
TXsilverado's Avatar
Originally Posted by dirt track racer 81
There's guhtentite and gorilla tight.. Haha
and the crank bolt requires nut busting tight.
surely you would have known 59 ft lb seems a wee bit high just zip it in with an electric impact and stop after about 5 clicks. the only torque specs that i follow anymore are head bolts.
Old Aug 21, 2018 | 11:09 PM
Dakota McCahon's Avatar
Registered User
Default Can't believe it.
To the *** hole who said 59 ft on torque spec **** you. Why would you put the wrong information like an *** hole. Doesn't matter if you thought you were being cute and silly **** you hard in the ***. Broken bolt later with an hour of getting it out again **** you gard mother ****** I will ******* knee you in the face so hard if I ever know who you are.
Old Aug 21, 2018 | 11:14 PM
FFDP's Avatar
#1 reason I find more than one source for information or disregard torque specs all together and do the german spec.
I've probably put 90% of cars back together without torquing a dam thing LOL. Head bolts, rod caps, main caps, crank bolts and specific stuff gets the ole bendy treatment but everything else is a blap blap with an impact lol.
Old Aug 22, 2018 | 04:59 AM
madmann26's Avatar
LOL. And to the person who thought 59ft-lb was realistic, you're an idiot.
Old Aug 22, 2018 | 10:14 AM
RedXray's Avatar
100% Redneck
I actually broke the impact socket before I hit that torque spec.
I was lucky I didn't brake off the bolt too
Old Aug 22, 2018 | 02:02 PM
firebladeJJ's Avatar
Some people will believe anything on the internet. Someone needs to put a sarcasm warning on that post.
Old Aug 23, 2018 | 07:10 AM
MrHorsepowerLSx's Avatar
11 Second Club
Post #7 gives the correct spec, I guess the dummy that believed it can read either
But in all honestly that really blows my mind how gullible and dumb some people really are, I wouldnt have made a bash post either for the ridicule that would ensue
Old Jul 30, 2024 | 07:53 AM
Rwags's Avatar
Registered User
Default Strap bolts torque specs.
Originally Posted by GM Muscle
Can anybody tell me what the strap bolts need to be torqued to on a '00 Silverado.
Thanks,
Andrew
Dear Andrew,
After hearing your desperate plea for the simple process of reapplying a nut to the thingy with the spirals, I noticed some of the comments were rude, uninformed & may have put you in danger as well as your viewerships safety(Im sure thats not too many, however).
It would seem my vehicle is a good example as it has 400k and this was my first replacment of the drivers shaft.
My drivers shaft was a simple removal. I used a 90mm set of tin snips to cut and remove the zip ties that held the drivers shaft to the part that spins the rear tires at the same time.
i reapplied the new drivers shaft into the vehicles transmission hole.
I then banged the heck out of finger tips when reintroducing the other end because it was not connected.
NEXT, I then applied NEW weather resistant zipties in the mannor the old ones were. As far as torque, I took them as snug as possible, then cut off the excess product.
I wanted this installation to last so I utilized an extra zip for any extra torque produced as I went from aluminum to steel shafts.
I hope this helps you & your viewership when reapplying a new drivers shaft to your vehicle properly as well as any torque specs required for the strap jacks(thats what brand mine were).
Safe Driving-
Dale
zblee
63
Jun 10, 2023 01:25 PM
shupe
Aug 5, 2015 06:45 PM
OLD BULL
Aug 1, 2015 05:00 PM
Ketis
Jul 23, 2015 12:37 PM
