Torque Specs Right?
Old Jul 21, 2005 | 10:16 PM
KySilverado's Avatar
Default Torque Specs Right?
Got my replacement verter and new flexplate in from PI. It's a long story and detailed in another thread.
Anyway, I've found torque specs for the flexplate to crank. 15-37-74 lb/ft. Three passes. Torque converter to flex plate at either 44 or 46 lb/ft. Do these sound right? Should I lock tite the torque converter bolts?
Second go around for pulling the trans is a lot easier. Took me 3 hours to get the trans out and flex plate off. Was like 8 hours the first time.
TIA for any input.
Old Jul 21, 2005 | 10:27 PM
XLR8NSS's Avatar
Adkoonerstrator
Those specs for the flexplate to crank are right. The converter to flexplate sounds right but, I don't know for sure. I just tightened them as tight as I could get and put a small spot of locktite on them too. Don't want those suckers backing out.
What did you get a new verter and flexplate for? I have been outta the loop lately.
Old Jul 21, 2005 | 10:35 PM
PI replacing the 10.75 bolt patterned verter they sent me with the correct 11.00 pattern. They also replaced my flexplate that I reworked to get the first verter to fit. Sent a brand new GM flexplate. I'm out the labor for the install a second time.
Old Jul 21, 2005 | 10:39 PM
Kano's Avatar
I used a little locktite on mine too
Im with X
might make things hard when you take it back off but
at least you can sleep at night
XLR8NSS's Avatar
Adkoonerstrator
Oh, ok. If I decide to restall this verter later on I'll talk to Jack about changing the bolt pattern. The only thing is that it looked like the 6.0L flexplate uses a large GM pattern that is 11.5" I just said screw it and drilled the crap outta the plate.
madmann26
Apr 29, 2020 09:17 AM
Jake75
Oct 2, 2015 02:28 PM
Wolftrk99
Oct 2, 2015 08:17 AM
Cammed4ever
Sep 30, 2015 03:38 PM
jscherbs
Sep 30, 2015 07:54 AM
