Torque Converter question
Old May 3, 2013 | 10:58 AM
vipergtrdj's Avatar
Default Torque Converter question
My friend has a 4L60E high stall converter (think he said 3200 stall) but its for his 94 k1500 (still a 4L60E). He is not going to use it, so he offered to give it to me. Would this work in my 00 silverado 4L60E? I will have my trans out for a rebuild next week so if it does work I can just throw it in and save some cash. I was reading the spline count could be different?
Old May 3, 2013 | 11:01 AM
kelsey_canard's Avatar
They won't fit.
Old May 3, 2013 | 11:06 AM
vipergtrdj's Avatar
That is a little disappointing ...... any idea what the differences were? What years would fit my silverado, or a good stock replacement converter with a higher stall, not anything really high. I know the TB are good but can't find a torque converter around from one.
Old May 3, 2013 | 11:08 AM
I can't tell you for sure, but the ls1 and lt1 converters won't interchange. Maybe a sponser will chime in with the correct information.
Old May 3, 2013 | 12:21 PM
Gearstar Performance's Avatar
FormerVendor
The spline counts are the same. But the shaft for the LT engine is 298mm and 300mm for the LS engine. Anything 98 & up would fit your Silverado.
Old May 3, 2013 | 12:25 PM
vipergtrdj's Avatar
Thank you for the information. My friend also has a converter from a trailblazer with the I6, he said stock stall for those were 1800-2000rpms, but I was reading if I used that it would be closer to 2500rpm behind a 5.3. Is this true? He is willing to give me the converter for free since he is trying to clean his garage up some
Old May 3, 2013 | 12:38 PM
Yessir. Grab her and slap it in there!
Old May 3, 2013 | 12:42 PM
vipergtrdj's Avatar
yay !! he just told me it has around 35k miles on it if that. So I will grab it and throw it in when I pull the 4L60E to rebuild I figured for free and I will have the transmission out anyways wont hurt anything to drop this in.
So the trailblazer stall should be enough to notice?
Old Sep 8, 2013 | 11:55 PM
therock's Avatar
Did you install the trail blazer converter? If so How do you like it?
TAPyvehc93
Jul 23, 2017 10:54 PM
OLD BULL
Aug 1, 2015 05:00 PM
BennyB
Aug 1, 2015 08:48 AM
KyleW707
Jul 29, 2015 08:17 AM
JordanH
Jul 14, 2015 03:46 PM
