tires for traction
Old Sep 12, 2005 | 10:52 PM
moregrip's Avatar
what a rush!
Originally Posted by BLOWN 364
I dropped the bomb on him tonight, he's got 10days, I'm sure he needs you now more than ever
Old Sep 15, 2005 | 09:42 AM
TurboGibbs's Avatar
Height will usually give you more traction than width. The more height the circumference is larger thus more rubber on the arch is touching the ground at the same time vs a shorter tire with the same width. Also the sidewall is more forgiving and gives more cushion.
Old Sep 15, 2005 | 09:45 AM
TurboGibbs's Avatar
Originally Posted by Naked AV
That's what she said.
"She" hasn't ever refered to you as old "tuna can" has she?
Old Sep 15, 2005 | 05:02 PM
Jeff Alexander's Avatar
width is better the taller the tire the more your aceleration suffers. that why when you lift a truck with taller tires you arent as fast as before unless you re-gear your rear end. it all depends on your setup.
gaps
Oct 15, 2015 02:53 PM
MA$TER_E
Sep 9, 2015 03:14 PM
bisqikss
Sep 8, 2015 03:35 AM
screaminian47
Sep 7, 2015 08:20 PM
the owl
Sep 4, 2015 04:09 PM
