are these taller tires hurting my performance any?
Old Mar 29, 2007 | 11:09 PM
trikeffex's Avatar
Default are these taller tires hurting my performance any?
hey guys.
when i bought my 06 silvy,it came with 1" taller tires on it.would i gain any performance back by puttin the stock size tires back on the truck?
thanks guys.
charles
Old Mar 29, 2007 | 11:13 PM
Wheatley's Avatar
Truck Sponsor
If you went to a 4.10 gear then you would get it back and then some.
Old Mar 30, 2007 | 12:38 AM
03GMC's Avatar
Word ....my truck came with 265/75/16s looks good but i know they're bigger than stock.
Old Mar 30, 2007 | 10:40 AM
xsports33's Avatar
If you put the stock tires back on you'll bring up your gear ratio and get a little more power. Like it says above, if you get shorter gears you'll get back the power. Also, with the stock tires back on you wont be pushing as much weight because of the larger tires.
Old Mar 30, 2007 | 11:48 AM
Hydramatic's Avatar
Yep. Stock on standard Silverados is LT235/70R16 size tires. Many of our trucks came from the factory with the optional LT255/70R16's though. I've heard one can put 265's and 275's on but I'm not so sure. Anyone wish to confirm 275's for me? On stock wheels of course...
Old Mar 30, 2007 | 12:20 PM
xsports33's Avatar
stock mine came with 265/70/17
Old Mar 30, 2007 | 12:50 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Originally Posted by trikeffex
hey guys.
thanks guys.
charles
What tire size is on right now and what was stock for your truck? Mine ('05) also came with 265/70/17's. What gears?
Running a larger tire is hurting performance by lowering the effective gear ratio and increasing rotating mass.
Increasing your final gear ratio will compensate some but if you are after performance you'll want the stock size or smaller tire diameter and lighter wheels.
Old Mar 30, 2007 | 01:15 PM
LS1TRUCKGUY's Avatar
i run 275/60/16 toyo proxes on stock wheels. tire is 29" tall. no clearance issues whatsovere, and im lowered 4/6
Old Mar 30, 2007 | 04:16 PM
budhayes3's Avatar
PT's Slowest Truck
FWIW, my truck came stock with 265/75-16...it was a factory optional tire size. 245/75-16 was the standard size. For a while I was runnin 285/75-16's which is a 33" tall tire...I didn't think it hurt performance, but when I went to the track and was runnin 2.4-2.6 60' times I realized that it did. I'm using a 31" tall tire now, hopefully I can get to the track this year and see if my 60' times improved any. Oh yea, factory 3.73 rear BTW.
Old Mar 30, 2007 | 10:21 PM
SK03Z71's Avatar
currently running Kumho ECSTA STX 275/70 R16 on stock wheels. 30" height.
I'm probably loosing a little low end torque, but I've added a few mods to the engine, and have no complaints, especially at top end!
