Are these the right accumulator pistons? Do I need both?
Old Jun 27, 2009 | 11:07 PM
0235SS93's Avatar
Default Are these the right accumulator pistons? Do I need both?
I'm installing a shift kit soon, so I figured I'd put in aluminum accumulator pistons too. I found 2 different kinds on ebay, which ones do I need? Small pin or pinless?
1) Aluminum no name small pin pistons from Oregon Performance Transmission
2) Sonnax pinless
Also, do I need both the fwd and the 1-2, or just one? If so which one?
EDIT: I read that the sonnax 1-2 piston will also fit the 3-4 piston? So if I wanted to replace all the plastic pistons in my tranny, I would buy 3 aluminum ones, right? One fwd and two 1-2 (also 3-4)?
Old Jun 28, 2009 | 11:17 PM
0235SS93's Avatar
Anyone???
Old Jun 29, 2009 | 07:29 AM
KySilverado's Avatar
Yes you need both if they are plastic and usually are. Forward and the 1-2. I've never installed the pinless style. They are suppose to be an improvement... actuate smoother, no binding and seal better due to no chance of leaks around the pin.
Digging through some pictures.
The 2 60e's I've done this pistion (3-4?) has been metal
This one has been plastic (1-2)
Then the plastic forward servo. This is where the pinless can be used.
Old Jun 29, 2009 | 01:37 PM
0235SS93's Avatar
K thanks! So I need a pinless foward and just a normal aluminum 1-2?
Old Jun 29, 2009 | 02:19 PM
Yes that sums it up nicely. Pinless is optional.
Old Jun 29, 2009 | 03:10 PM
0235SS93's Avatar
Ok Thanks!
Old Jun 29, 2009 | 08:34 PM
FLT's Avatar
FLT
FormerVendor
I would just get the aluminum pistons for both. Just my 2 cents. Vince
Wolftrk99
Dec 3, 2015 08:12 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
turbo6c3
Oct 5, 2015 06:11 PM
sTNT971
Sep 26, 2015 04:22 PM
