Th400 or 4l80...?
Old Dec 15, 2013 | 10:37 AM
6.0l RST's Avatar
Yea no way I can afford a gv overdrive
Old Dec 15, 2013 | 01:50 PM
oakley6575's Avatar
I've had both in my truck. I liked the TH400 but I ran 4.10 gears and it was a bitch to get on the freeway. I have a 25 min 65mph freeway drive to work and it got old. I really like my 4l80e. I just like having the ability to tune shift points, firmness, ect.
Old Dec 15, 2013 | 06:47 PM
kelsey_canard's Avatar
Originally Posted by GMCtrk
Frankly, I'm surprised the th400 isn't a more popular swap here. I seriously considered it, but didn't feel like having to change the crossmember and driveshaft since I had already been running the 80 for several years. I don't drive my truck much at all so it made a lot of sense. The th400 can be built stronger for cheaper. No OD isn't a big deal to me. Just wasn't sure how I'd feel about driving around with no lockup on a 3400 converter.
I agree. If n/a I would be hesitant to swap though. A big converter and gears would make the drive ability a lot worse, and without those on a n/a setup you are leaving some on the table.
A turbo setup would be different tho. Most people here run small cams,small converters, and streetable gears with a turbo setup. This IMO, makes a th400 swap a lot more driveable.
Old Dec 16, 2013 | 02:55 AM
James B.'s Avatar
One point I haven't seen mentioned here yet is final drive ratio. With the power level goals you have you don't need low rear end gears for a strong launch because traction problems would make first gear useless. Consider swapping to 2.76:1 gears as part of the expense of choosing the TH400 over the 4L80-E. This will keep the RPM down on the highway and move the range of shiftpoints higher up in MPH. (First gear WOT in that scenario would take you to 75+ mph.)
You're used to the wide gear ratios and overall range of a 4L60-E. With a 4L80-E you lose overall range in favor of closer ratios. A TH400 has the same ratios and range of the the first three gears of a 4L80-E but you lose the 0.75:1 overdrive making it the narrowest overall range choice of the three transmissions.
Old Dec 17, 2013 | 12:14 PM
slowswb's Avatar
I just sold my th400 off because i didnt like going back to overdrive 80e swap with a circle d converter.
Old Dec 17, 2013 | 12:15 PM
slowswb's Avatar
if you had overdrive before your not going to like the th400 swap.
Old Dec 17, 2013 | 08:55 PM
SnIpEz's Avatar
It can be built cheaper, but it won't really be stronger. The OD is the 4L80E's biggest weakness at high power levels.
Originally Posted by gamble686
Now the best of both worlds is a 400 with a GV overdrive. However, that is very expensive. It also can be modified to work with your speedo without too much effort and even the column shifter can be modified to work.
Not necessarily. A 4L80E is a much better option than a TH400 with a GV overdrive unit. The GV sounds nice on paper, but it most certainly has it's downsides that do not come with a 4L80E. If you do not have an electronic speedo, although it is stupidly costly for what it is, a mechanical speedo/tailhousing setup on a 4L80E is still the way to go.
Old Dec 17, 2013 | 10:41 PM
oakley6575's Avatar
How many gv overdrive units have you run?
Old Dec 17, 2013 | 11:11 PM
SnIpEz's Avatar
Well I build racing TH400s and 4L80Es professionally, so I've seen a number of them over time, but have not run one myself. My old boss, who owned the shop I worked for (Jake's Performance), had one on his Chevelle and also hated it. How many TH400s have you built and how many GV's have you installed?
Old Dec 17, 2013 | 11:21 PM
oakley6575's Avatar
I'm not a transmission builder. Never said I was. So I've never built a TH400. I ran one in my truck for a while but I had a pro build it. I'm curious at what problems you have run into with the GV's
