TECH: 6 Lug 14 Bolt SF into an Avalanche
Old 08-11-2009, 10:54 PM
  #41
I have a gauge for that
Atomic's Avatar
What rotors will fit the 14b sf axles? Or another way, what came with this axle and disc brakes and are they the same diameter as the half ton discs?
Old 08-12-2009, 09:50 AM
  #42
DrX
DrX's Avatar
This was originally a drum setup. I am using my 13" AV rotors, but I believe the axle flanges were turned down a little to fit. axisT6 can confirm.
Old 08-12-2009, 10:07 AM
  #43
Atomic's Avatar
I am wondering if discs from a vmax will fit without having the grind the flange?
Old 02-14-2013, 05:37 PM
  #44
Registered User
smkrecon's Avatar
Default Mark's CAD info for brackets
I was researching axle upgrades for a 2004 Tahoe Z71, and came across this excellent write up. Last weekend my G80 blew out, and the weak 10 bolt is non-recoverable. I am bought a 14b sf out of 97 van for $200. My next step is to make the brackets. I work at a shop with a laser and water jet. I was wondering if you had Mark's Cad program for the bracket cuts. This is my daily driver, and trying to find brackets fast.
Old 02-14-2013, 05:44 PM
  #45
Atomic's Avatar
Which brackets?
Old 02-14-2013, 07:10 PM
  #46
DrX
DrX's Avatar
Originally Posted by Atomic
Which brackets?
I think he is referring to all of them if it is going in a Tahoe(as per posts 25 and 28). Mine started out as bare tubes. Everything else was fabbed to duplicate the stock Av 5-link setup.
5.3Okasai
03-09-2022 01:07 PM
FlowmasterMufflers
08-28-2015 10:58 AM
FlowmasterMufflers
08-14-2015 12:47 PM
Kaldar
07-27-2015 06:42 PM
Quick Reply: TECH: 6 Lug 14 Bolt SF into an Avalanche
