TCC not locking and intermittent P01860 code
Old Aug 18, 2025 | 09:56 AM
RDF1's Avatar
DuNnO
5 Year Member
Originally Posted by Bluecollar Hotrods
I swapped in my spare PCM this morning and flashed it with my tune file. Still does the same thing. My next move is to eliminate the adapter harness between the factory harness and the connector on the 4L80E.
I really do not know what else it could be at this point. I'll post up my tune file for anyone that is interested.
Throw that harness away and just swap 2 pins. Ive had nothing but trouble out of those adapter harnesss.
Old Aug 18, 2025 | 09:58 AM
RDF1's Avatar
DuNnO
5 Year Member
My current tune if anyone is bored or curious.
Did you follow the diagnostic i posted?
Old Aug 18, 2025 | 10:17 AM
10 Second Club
I attempted to, I don't fully grasp everything outlined in it. Automotive wiring isn't my strongest skill. I feel like it has to be wiring related at this point.
Old Aug 18, 2025 | 10:19 AM
10 Second Club
I need to look for that diagram again on which pins to swap. At this point it's my best option I think.
Old Aug 18, 2025 | 10:31 AM
RDF1's Avatar
DuNnO
5 Year Member
Just swap S and U at the Trans 20 pin connector.
And that code is a wiring/solenoid code.
If you can put ground to pin S and the TCC noid doesnt click, then you have a internal wiring issue or a bad solenoid.
Old Aug 18, 2025 | 11:39 AM
10 Second Club
Thank you, that makes more sense to me.
This was the diagram I had saved:
https://lt1swap.com/4l60e_4l80e_harness.htm
Old Aug 19, 2025 | 10:58 AM
10 Second Club
I am forever in your debt. Got rid the harness, moved pins in factory connector. Works like it should. Im slipping in my old age, I am kind of pissed at myself for not verifying that all the pin locations were correct. Lesson learned.
For anyone else following along, or who might stumble across this thread in the future...
Cliff notes: that cheap adapter harness was pinned incorrectly.
Old Aug 19, 2025 | 11:31 AM
RDF1's Avatar
DuNnO
5 Year Member
And now you understand why i dont trust that junk.
Its much easier to just swap those 2 pins than it is to use the adapter.
Old Aug 19, 2025 | 11:45 AM
strutaeng's Avatar
5 Year Member
I'm also a believer of simply swapping the wiring/pins. The wiring for the additional speed sensor is basically already there, might as well take advantage of it. Costs nothing but a bit of time and electrical tape.
'm glad you figured it out. Great job! 👏🙏
Old Aug 19, 2025 | 01:49 PM
10 Second Club
It 100% is. When I didn't know any better, I used a similar kit from Speartech on my 2001. It never gave me trouble. However it wasn't cheap, and now 9+ years later it's almost double what I paid. I have enough junk harnesses I keep around for connectors and such, I literally could have grabbed a speed sensor plug and the two wires with the pins and added it to my existing harness. Then swapped pins in the connector. That would have been free.99
Live and learn...
THIS right here is why I prefer the forums. If I had asked on FB, I would have gotten 50+ replies telling me to hit it with my purse.
ericgerber79
21
Jun 9, 2017 09:26 AM
1bad2k
Jan 23, 2015 12:56 PM
cwalker2006
Apr 3, 2014 02:44 PM
454navyss
Oct 14, 2010 06:05 AM
JeevesRules
May 23, 2007 09:13 PM
