4l80e swap converter problems
Old Apr 2, 2014 | 01:06 PM
cwalker2006's Avatar
Default 4l80e swap converter problems
did the 80e swap, put a new triple disc from circle d. frost conversion harness. at cruising speeds it will lock for a couple miles then it just unlocks and it will not lock back up until I delete the code that pops up. its p0894 anyone else have that code when using the conversion harness?
Old Apr 3, 2014 | 01:39 AM
Suburbazine's Avatar
Have you tuned out all the codes that the kit needs fixed?
Originally Posted by Steve@TunedByFrost
For GenIII all he needs to do is MAX OUT the enable temp fields for the P1870 Diag (this is NOT setting the DTC to No Error; it's making the DTC not run by setting the enable temp to 495 or whatever max is). After that, set P0785 and P1860 to No Error Reported in the DTC list.
I think there's another setting related to a transmission table around the 60mph area that causes the TCC to kick out and set a phantom 894 code. Geoff@EPS knows what it is and fixed it for me, but I don't know what it was.
Old Apr 3, 2014 | 02:51 AM
We took care of codes that were on the bag when I received the harness. We are going to set the p0894 and the other two you mentioned to no error reported and see if that fixes it
Old Apr 3, 2014 | 03:26 AM
Check with Steve (steve@tunedbyfrost.com) to make sure those codes are applicable for your model year. If you just bought the harness and didn't have any email interaction, chances are you didn't get all the codes you needed anyway.
Old Apr 3, 2014 | 02:44 PM
I emailed him when I got the harness. He said the codes on the bag and my tuner skulls know the rest. Ill email him again today. Hopefully I'll get some better insight
XL7
May 5, 2022 01:48 PM
bighouse
Sep 27, 2015 12:37 AM
lycominghunter
Jul 29, 2015 04:24 PM
alex226
Jul 16, 2015 10:55 AM
lxcoupe
Jul 14, 2015 10:14 PM
