TBSS AWD 60E broke, let's talk 80E swap
Old Nov 22, 2012 | 04:32 PM
LIL SS's Avatar
What year is it? The PCM is a pain in the TBSS when it comes to the 80e. Also, the AWD transfer case was never used in combo with a 80e.
It's an 07..
The HD GMC Denali Quadra steer used a 4L80E with AWD. I know if had a 6.0 in it. I will try to find the tune of my dads old truck and confirm the 4L80E.
Thanks SilverZ..
Old Nov 22, 2012 | 05:03 PM
03sierraslt's Avatar
Quadra steer was not used past 2004, All of the quadrasteer Denali's used a NVG 149 T-Case and never had a 80E. I have one.....
Old Nov 22, 2012 | 05:04 PM
Originally Posted by LIL SS
It's an 07..
Thanks SilverZ..
What year was your dads truck? Quadra Steer Denali's were made from 02-04, LQ4 6.0, 4L65E trans, NVG-149 Transfer case, Dana 60 Rear end with 4.10 Gears. In 05 they dropped the Q-Steer and dropped the Ext cab and went crew cab.
Old Nov 22, 2012 | 05:13 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I'm not sure a transfer case input gear is available for the TBSS. I can't remember, but I don't think they used the NVG149. I could be wrong...
PATC (and probably others) have a 27 spline output shaft for the 80E, and that might be the way to go in the TBSS.
Old Nov 22, 2012 | 05:19 PM
Roger- No, I dont think they used the NVG-149 Either. From what I can find they appear to use a NVG-126.
Old Nov 22, 2012 | 05:24 PM
1FastBrick's Avatar
Custm2500's Rude Friend
You might be able to have the gear re splined in the same fashion.
Old Nov 22, 2012 | 05:25 PM
I think he'd be money & effort ahead to get a 27 spline output for the 80E.
Old Nov 22, 2012 | 05:38 PM
1FastBrick's Avatar
Maybe, but I have heard those are weak and have tendency to break under heavy load.
Old Nov 22, 2012 | 05:43 PM
1FastBrick's Avatar
Found this... model NVG 120, RPO NR9
Here... https://ls1tech.com/forums/13218450-post14.html
Now I need to research them...
Old Nov 22, 2012 | 08:37 PM
LIL SS's Avatar
03sierra, I believe it was an 04. I don't remember for sure what trans was in it, but I thought is saw things in the tune that made me think it was an 80e, let alone it was an hd and behind a 6.0..
I could definitely be wrong.
