TB stall...
mine would stall to 2600 when i first got it, but now only makes it to 22-2300 because of the longtubes. 60' times went from 2.18-2.23 to 2.02-2.05. got a 1.95 on slicks. its a good cheap mod, but im thinking about having it restalled to 3200
foot stall wont get you the stall you want. converters go by flash stall. holding the brake will never show you the true amount of stall since rear tires will break lose before that. only way to measure true stall is with transbrake. so for the most part flash is what you go off not brake
Originally Posted by Quik
thought it was about 2400 with 4.8
thought it was about 2600 with 5.3
thought it was about 2800 with 6.0
with my setup it sees about 2800-2900 flash speed
Mine hits at 2800.
Since I'm a bit lazy today due to a cold...
What GM part number are you guys ordering? I plan on putting in a TB stall when I do the 6L swap, since it should be cake with the engine out of the way....
http://cgi.ebay.com/ebaymotors/4L60E...QQcmdZViewItem
