Taking the 4l80e plunge!
Old Feb 13, 2013 | 11:21 AM
DNATBSS's Avatar
Default Taking the 4l80e plunge!
Im taking the plunge into the 4l80e swap
Just ordered the 4x4 swap kit from PATC for the 4l60-4l80 swap!
Going to get this 4l80e from Kingman, AZ on saturday for $500.
2001 silverado chevy truck parts 2500HD 4X4
he claims the tranny worked fine when he parked it. The transfer case went out. It seems like a good deal to me.
any suggestions on inspecting this thing? Or maybe anything usefull that i could pick off this truck?
wish me luck!
O ya, almost forgot.......... Hello. Im new here. Nice to meet everyone
Last edited by 1FastBrick; Feb 13, 2013 at 09:08 PM. Reason: Broken Non sponsor link removed.
Old Feb 13, 2013 | 12:11 PM
DNATBSS's Avatar
almost forgot.....
my truck is a cc 1500. Donor truck is a 2500
yes i plan on getting driveshafts made and doing a segment swap.
Old Feb 13, 2013 | 09:19 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Your link was broken and didn't lead any were. It was also technically a non sponsor link so I removed it.
Pick up the Hydroboost and Pedal if it is still on the truck.
Inspecting the fluid will be the best you can do. Maybe drop the pan and make sure there are no chunks in there.
BTW in case you are not aware, you have to pull the entire trans apart to install that out put shaft. Some people have broken those shafts from PATC in the past under heavy power.
It would be better to leave the factory out put shaft in there and change the input gear in the transfer case.
HTH!
Old Feb 14, 2013 | 01:40 PM
DNATBSS's Avatar
HTH!
Damnit! i jumped the gun and ordered to fast. I was under the impression that the input gear in the transfercase is what i was getting......
maybe i can send that output shaft back and order the input gear....
thanks
Old Feb 14, 2013 | 02:00 PM
kelsey_canard's Avatar
Be sure to get the 4l80 dipstick. Good luck, you'll love the 80
Old Feb 14, 2013 | 02:21 PM
DNATBSS's Avatar
WOW!
Good catch on the output shaft 1FASTBRICK!
that will save me $450
so i looked through the sticky on the input shaft swap.........
will the NP241 32 spline input shaft fit in my transfercase with no modifications?
i thought my t-case was a 246
2004 ccsb z71 5.3
thanks guys
mitchellmade
Sep 27, 2015 08:25 PM
zachman078
Sep 21, 2015 04:36 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
wcrum17841
Aug 24, 2015 08:30 AM
brandon6.0
Aug 19, 2015 07:48 AM
