TA performance rear cover ??
Old Oct 6, 2011 | 11:08 AM
outlaw38's Avatar
Originally Posted by Gadgetized
I am out of town so I can't crawl under my truck to look. Does it have lock washers on the girdle studs, or are they flat washers? If they were lock washers, I would swap them for flats.
It does not have any washers on the locknut
Old Oct 6, 2011 | 11:40 AM
Mangled03gmc's Avatar
Baltimore Whore
I will agree with Roge.. They need some type of sealant on the threads.. I is kinda a given.. It is just a threaded hole, so oil will makes it way through.. But not sure why you have DRIP..
Old Oct 6, 2011 | 12:20 PM
badz24s's Avatar
formerly b4vwannabe (2/4/2012)
Originally Posted by outlaw38
Yes I filled it to the stock fill plug.
For the people who may stumble upon this thread in the future:
-the stock full level is 5/8"--1 5/8" below the stock fill hole.
-the cover bolts that you need are metric, you will have to specify this when ordering or you will be sent standard thread bolts.
The pipe thread sealant suggestion sounds like the best thing.
Old Oct 7, 2011 | 11:56 AM
budhayes3's Avatar
PT's Slowest Truck
I sealed mine with teflon tape and they stopped leaking but the gasket that came with the cover blew out on the sides by the carrier bearing oil feed holes. (vent is good and not clogged) Got a factory gasket and sealed with teflon tape and it was good for a few months, then the preload bolts started leaking again. Now I just hit it with a shot of brakleen occassionally I figure that I'll deal with it when I can afford to do gears and a trutrac.
USMCvet0311
Sep 30, 2015 10:34 AM
DarkhorSe_SS
Aug 20, 2015 08:58 AM
Ketis
Jul 23, 2015 12:37 PM
cbhedrick
Jul 20, 2015 10:12 PM
jmarkway
Jul 18, 2015 09:23 PM
