t56 guys, what clutch are you using?
Old Apr 28, 2007 | 07:23 PM
  #21
adam1803's Avatar
Originally Posted by TurboGibbs
I just thought of something; you being in PC you don't have a hill to worry about within 150 miles. Unless you make frequent trips up north you'd be ok with 1800rpm or so on the interstate in the flat lands. Unless you have a monster cam or something that is.
yeah i was thinking the same thing when i read your post. I barely ever see the interstate anyway. I'll most likely be sticking with the 27" tire on the street. I have 26" slicks for the track. If i switch tires then i'll switch gears as well, but don't plan on it.
I think im going to give the LS7 clutch a shot and see how it holds up. For the price i'll be happy if it last a year.
Old Apr 28, 2007 | 10:21 PM
  #22
TurboGibbs's Avatar
Well, it is all about balance for your application. If you rarely hit the interstate then i'd go a little more agressive on the gear. I'm not exactly happy with 1st gear with my 4.30's & 31.5" tires.
Old Apr 30, 2007 | 12:33 PM
  #23
vanillagorilla's Avatar
Originally Posted by Torque_Wrench
Holy stink...you serious? What the F#ck is the Gorilla running?
Just a turbo 4.8, but I have A LOT of weight compared to you RC guys. That's ultimatley what kept killing the stage 3's;the daily use with +5000lbs on it.
For the record I had 4.56's with a 31.9" tire and it needed more. On the hiway I'd chug along in 6th or it'd be in boost. So I'd either use 5th (which defeasts the purpose of a 6spd) or I'd speed (85-90) in 6th.
Old Apr 30, 2007 | 01:06 PM
  #24
adam1803's Avatar
I decided to try a spec stage 3+, well see how it holds up.
Old Apr 30, 2007 | 01:24 PM
  #25
Spec recommended that I go with that or a Stg. 5. I didn't want to go with a Stage 5 though due to drivability and I've heard that Exoskels are a bit much to drive with daily. Plus I don't think they're really designed to work stock hydraulics.
Old Apr 30, 2007 | 04:20 PM
  #26
TurboGibbs's Avatar
Exoskels are fine with stock hydraulics but not DD IMO. Don't know about the stg 5's
Old Apr 30, 2007 | 04:22 PM
  #27
adam1803's Avatar
The stage 5 is race only according to Spec. The 3+ has better street manners than the 3 supposedly and is rated to 850 ft lbs.
Old Apr 30, 2007 | 10:02 PM
  #28
TurboGibbs's Avatar
Yeah, stg 5 is a solid hub disc and is not daily drivable.
Old May 1, 2007 | 04:01 PM
  #29
The stage 3+ is the stage 5 pressure plate and the stage 3 clutch, or vice versa. I was told it has stage 5 holding power and stage 3 streetability.
BKnBLK05
Dec 28, 2015 08:52 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
