T/A Girdle bolts?
Old Aug 16, 2006 | 10:15 PM
SSlow 4.8's Avatar
Default T/A Girdle bolts?
I have the standard 10 bolt truck rear end on my 01 silverado... I just bought a used t/a girdle from a member on the boards... i was wondering what bolts i am supposed to use with this, bc the stockers arent long enough. And also, where i could get them from?
TIA
Old Aug 16, 2006 | 10:23 PM
SnakeOiler's Avatar
You gotta get some that are longer. I used 35mm length ARP and I know some others have used a 40mm length.
I got mine from Summit.
Old Aug 16, 2006 | 10:43 PM
SSlow 4.8's Avatar
thanks, let me do some research and see if i have any more questions
Old Aug 16, 2006 | 10:45 PM
sliderbkt's Avatar
I just went to Ace and bought some for mine. Nothing special, but they seem to work.
Old Aug 16, 2006 | 10:51 PM
SSlow 4.8's Avatar
hey snake.. i was on summit...i'll probably go with the 35's... im guessing i should go with the largest wrench size.. which is 10mm?
i know stockers are 13.. should i use some washers? or will it matter?
Old Aug 16, 2006 | 11:30 PM
SnakeOiler's Avatar
If they are ARP bolts, then they come with washers. I think mine were 12point 10mm
Old Aug 16, 2006 | 11:58 PM
SSlow 4.8's Avatar
alrighty, i appreciate it
Old Aug 17, 2006 | 02:00 AM
Mr. Sandog's Avatar
I've got some if you need them.
Old Aug 17, 2006 | 02:24 PM
SSlow 4.8's Avatar
baaah.. just ordered some last nite, thanks tho.
Old Sep 12, 2006 | 12:15 PM
SSlow 4.8's Avatar
ttt... so im doing this today...
questions, these bolts dont seem to go into the rear end w/o some type of effort... the hole is much smaller... looks like i have to rethread the holes... how should i go about this?
