t/c spacer?
Old Mar 7, 2009 | 02:35 PM
forbes's Avatar
Default t/c spacer?
went to install my t/c today.... and it seems to have some play.... like it needs a spacer or something.... is this common? and what would i use to space it out....
any help would be appreciated...
Old Mar 7, 2009 | 02:53 PM
blklime02's Avatar
wat do u mean by T/C????
Old Mar 7, 2009 | 02:57 PM
1_fastsilverado's Avatar
Torque converter...I haven't heard of anybody needing a spacer, what brand is it?
Old Mar 7, 2009 | 03:01 PM
forbes's Avatar
an art carr.....
it was outta of an 05 4l60e
which is what is it going into...
but the flexbolts bolts bottom out with about a 1/4 inch of play.... tween the flexplate and verter....
Old Mar 7, 2009 | 03:40 PM
454navyss's Avatar
did you get new bolts or are you using the same bolts? did you lay the next to each other to see how they looked?
Old Mar 7, 2009 | 03:57 PM
budhayes3's Avatar
PT's Slowest Truck
Maybe that verter requires shorter torque converter bolts?
Old Mar 7, 2009 | 06:21 PM
forbes's Avatar
got the shorter bolts....
Old Mar 7, 2009 | 06:30 PM
GMCtrk's Avatar
I thought there was supposed to be space between the converter and flexplate?
Old Mar 7, 2009 | 07:34 PM
forbes's Avatar
dude... don't tell me that............
anyway.. i got that part done... now i just have to finish bolting everything back up........
Old Mar 7, 2009 | 07:40 PM
black4.8's Avatar
push converter tight toward tranny, if there is more than .187 between converter and flexplate you need a spacer/washer. i just slide a grade 8 washer in there than bolt it up.
