swaybar q
Old Feb 16, 2009 | 08:28 PM
006rcsb's Avatar
Default swaybar q
im finding different part numbers for rear swaybars for 2wd or 4wd, my truck is a 4x4 but its lowered, lift block removed and shackle with hanger on the way. Is the only difference in the sets the end links being longer for the 4wd? because if so I would probably want the 2wd, but im not sure. btw im looking at the addco kits on ebay it shows part number 2121 for 4wd and 631 for 2wd. how is addco brand I was looking at hellwig too the bar is only an 1/8th inch larger diameter, but its like 100 bucks more though...
Old Feb 17, 2009 | 07:06 AM
Coban's Avatar
I have an addco swaybar. I'm 2wd. It came with 2 different sets of end links (bolts and sleeves) to be used with:
1) stock height or 2" drop
2) 4" drop.
The bar is a good price but honestly, I wish the end links attached the same as they do on the Tahoes. It looks cleaner to me.
Old Feb 17, 2009 | 07:41 PM
006rcsb's Avatar
ok well thats good to hear, are you talking about how the sway bar faces rearward instead of forward?
Old Feb 17, 2009 | 08:37 PM
Coban's Avatar
Well I like the forward facing ones better too. But if you look at the type of linkage used on the tahoes for their stock swaybar then look at what addco uses, its difference. I doubt one works better though.
Old Feb 17, 2009 | 08:58 PM
KevinF56's Avatar
buy the one for the 2wd truck. that's what i had on my truck and it had the lift block removed and 2" shackles just like you.
Old Feb 17, 2009 | 09:44 PM
006rcsb's Avatar
awesome, thank you for the info!
vmaxpro
Sep 28, 2015 11:10 AM
tbyrne
Mar 9, 2007 02:02 PM
GoldenVelvet
Sep 22, 2006 01:56 AM
hodgeee
Apr 14, 2003 03:12 AM
