How To: Front Swaybar Install.
I was going to d a write up on a front sway bar install but its pretty straight forward
1. Unbolt and remove rodends.
2. Unbolt and remove scrape plate.
3. Unbolt and remove two swaybar mounts.
4. Remove unbolted swaybar.
5. Revers processes with new swaybar.
That's it.
Ill take this time to go over some of the differences between a stock sway bar and a typical aftermarket bar.
The pic is HUGE and I put notes on it. ENJOY!
That's it.
Originally Posted by 04sierra
Why the Hellwig over the more used Hotchkis? Price? Bigger diameter? Just curious.
Let us know how it handles.
The rear Hellwig way bar is AWSOME and I will have to eventually trade my Addco for it.
As far as improved handling.... I cant really say as it was night and day. The truck is flater in a turn now. The tire complaint I get now is from the back tires now. At the limits of traction there is a bit of overstear now where as before it was more neutral. The real question is are the limits of traction higher now? I can already take a turn harder then the seats can keep you put (are seats considered part of the suspension?) so its hard to say. Ill take it out the weekend and through the hills and see.
Next suspension mod is a panhard bar.
So do you consider the Hellwig a compromise or do you think it is better than the Addco?
I'm watching to see if you can hit your 1 g goal. Good luck.
I really would have like to have kept them matched.
It looks like Hellwig adjustable mounts will fit on the Addco rear bar.
That will be a good compromise.
But I need a panhard bar next.
FlowmasterMufflers
Aug 28, 2015 12:48 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
