swapping gears????
Old Dec 30, 2004 | 04:39 PM
Default swapping gears????
i'm wanting to swap my gears out. i have 3.42 with the g80. i'm wanting to go to 3.73. what do i need and can i get it from summitracing? I have a gift certificate to summit and thats why i'm asking. How much will it cost for the swap?
Old Jan 1, 2005 | 02:39 PM
silent1's Avatar
You should be able to find an install kit from them and the gears you want. Other than that, you'll need dial indicators, torque wrenches, and know what is/how to set the proper pinion pre-load, ring gear to pinion backlash, and so forth.
Old Jan 1, 2005 | 09:16 PM
KeukaZ71's Avatar
ya, there should be kits out there that have everything you need. the kits should come with all the bearrings and shims you need.
if you don't have posi, i recommend putting one in at the same time you change the gears since the carrier will already be out.
good luck
1slwgto
Aug 16, 2015 06:40 PM
CammedZ71
Aug 2, 2015 01:44 AM
iregret
Jul 27, 2015 10:32 PM
Ketis
Jul 23, 2015 12:37 PM
lxcoupe
Jul 14, 2015 10:14 PM
