Strange Leak
Old 09-17-2015, 06:32 PM
Jaz
Registered User
Jaz's Avatar
Default Strange Leak
Seems as if the output shaft/yoke seal is leaking from somewhere. Seems dry around the slip-yoke itself, u-joint is slightly greasy. But the bottom of the body is covered. Any ideas?
Attached Thumbnails Strange Leak-img_1512.jpg   Strange Leak-img_1513.jpg   Strange Leak-img_1514.jpg
Old 09-17-2015, 10:14 PM
Custm2500's Rude Friend
1FastBrick's Avatar
Most likely the vent tube Spewing it on the bottom side of the floor.
This can occur under High RPM especially if the case is over full.
Old 09-18-2015, 05:09 PM
Jaz
Registered User
Jaz's Avatar
Do you mean the transfer case vent tube?
Old 09-18-2015, 09:23 PM
1FastBrick's Avatar
No, The transmission case has a metal blow down tube in it with a rubber line connected to it. Usually exits toward the rear of the trans area.
91LT16SpeedFormula
10-17-2015 08:01 PM
03sierraslt
14
10-09-2015 05:53 AM
02AWDAWSDenali
10-01-2015 05:08 PM
726.0chevelle
09-12-2015 09:24 AM
Quick Reply: Strange Leak
