Steering box
Old Dec 21, 2011 | 03:10 PM
Slow91z's Avatar
Default Steering box
Been noticing some play in my steering and when I had it on the rack the other day I wiggled everything around and it's definitely from the box (200k miles).
So I guess my question is, is there an adjustment like an older steering box, or do I need to replace it and if I need to replace it is there a quick ratio one available?
Old Dec 23, 2011 | 10:17 AM
TURBHOE's Avatar
you shold be able to back off that nut and adjust the ring gear. just don't over do it.
Old Dec 23, 2011 | 10:27 AM
TX Tahoe Z71's Avatar
I replaced the inner and outer tie rods, pitman arm, idler arm, and idler pivot with Moog ones, and the steering still had play. Tried adjusting the nut on top, no luck (127k miles), then I found a rebuilt one on ebay for a great price and that has made worlds of difference. Much easier to turn the wheel and no play on the freeway. The worm gear on the inside wears out (at least that's what my mechanic friend told me)
Old Dec 23, 2011 | 10:29 AM
Slow91z's Avatar
Thanks guys...I'll play with it and see what happens.
Old Dec 26, 2011 | 01:38 AM
02'Z71ONDUBZ''s Avatar
make sure not to tighten the screw more than a 1/4 turn after you loosen the nut
Avalanche2002
Nov 30, 2015 07:31 AM
dsbodley
Nov 14, 2015 09:46 PM
Wrecker 426
Oct 7, 2015 12:11 PM
BCraven1018
Oct 1, 2015 08:22 PM
Blklgt
Sep 28, 2015 03:21 PM
