Starting in 2nd Gear
Old Sep 28, 2008 | 06:10 PM
MikeGyver's Avatar
Default Starting in 2nd Gear
Because starting in 1st takes so much concentration to keep from smoking 'em, I tried 2nd. As long as there are no crosswalk stripes on the road, I can take off pretty hard witout wheelspin.
Which is harder on the trans: banging the 1-2 shift, or starting in 2nd?
Old Sep 28, 2008 | 06:16 PM
006rcsb's Avatar
i would imagine banging the 1-2 shift would be harder on the trans since starting in 2nd would only be harder on the clutch.
Old Sep 28, 2008 | 06:43 PM
MikeGyver's Avatar
It's a 4L80E, sorry I didn't mention that.
Old Sep 28, 2008 | 06:48 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Get sticky'er tires and launch like a man
Old Sep 28, 2008 | 07:29 PM
006rcsb's Avatar
o i c ..... the way you said it, it sounded like you had a 5 speed.... lol +1 for stickier tires and maybe some caltracs, and manually shifting an automatic=tranny death, unless it has been built for it.
Old Sep 28, 2008 | 08:15 PM
MikeGyver's Avatar
Thanks guys. Yeah, I'll probably try something sticky when I'm ready for the strip. I just don't want anything for day to day use that will wear faster than these truck tires already do. Oh, well, launching like a "not man" saves money on gas, anyway.
Old Sep 28, 2008 | 08:23 PM
95 bright teal's Avatar
DONT MANUALLY SHIFT YOUR AUTO, its ok to do it on occasion, but if your forcing it into second every time you leave a light you will burn that sucker up
Old Sep 28, 2008 | 09:24 PM
vanillagorilla's Avatar
I'm not sure how exaclt you're launching in second, but if you're sitting on the converter at all it's bad news. Because the gear ratio in 2nd is a lot higher than first, that converter is going to create a ton more heat as it will probably stall a lot higher. It's also a good way to roll the sprag.
ferrellrooster
Mar 6, 2025 03:22 PM
Oobray
Jun 13, 2022 03:38 AM
1slwgto
Aug 16, 2015 06:40 PM
Ketis
Jul 23, 2015 12:37 PM
lxcoupe
Jul 14, 2015 10:14 PM
