Stall rates?
Old May 5, 2007 | 03:17 PM
nonnieselman's Avatar
Default Stall rates?
I know there has to be somewhere that would suggest what stall speed would be more effiecent with certian Power Adders... Cant find anything..
My Delima... Stock TB Converter ~$250 (should stall up to ~2800 with STS)
Yank TT2600 ~$475
Yank TT3000 ~$575
um.... that seems to be my choices.....
Truck goin to be used as a truck.. Towing, hauling, DD and racing.
Yank says
"The oversized lock-up clutch of the Truck Thruster 2600 will allow you to maintain the full towing capability intended by your OEM torque converter. "
PI Viglant Series, Said that its possible to tow, but they wont recommend it..
They are out the window...
So is Yank acctually worth the extra ~$225-325???
Old May 5, 2007 | 03:21 PM
nightrunner's Avatar
Mr. Obvious
ive heard that with much power, the TB converter fails on most cases
a 24-2600 converter is good for a twin screw/radix blower
and a 2800-3000 is good for turbo or centrifugal blower
and a 2800-up is good for NA apps
Old May 5, 2007 | 03:40 PM
Dock Rocker's Avatar
Nonnie go ahead and spend the $$ so you dont have to go back in that trans!
Old May 5, 2007 | 04:17 PM
cyazo6's Avatar
check this page out! http://www.converter.com/faqs.htm
Old May 5, 2007 | 06:06 PM
Bish's Avatar
I run a PI triple disk and I tow about 5.000lbs about once a month sometimes for a couple thousand miles per trip. I've got 45K on it now and it is the same as when new. I have some standard bolt-ons but nothing serious and I thrash my truck semi-regularly. I have been very happy with PI.
Old May 5, 2007 | 06:11 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
I would look at one of the billet converters for FI applications. You'll pay more now but less later
Old May 5, 2007 | 06:50 PM
kbracing96's Avatar
I got a DACCO reman TB stall in mine and it stalls around 22-2400 normaly, but can push it out to 3300 and 10 psi on the line. Still holding strong after 2 years and 35k miles in my stock, shift kit vette servoed 4l60
Old May 5, 2007 | 06:56 PM
Wilde Racing's Avatar
How do I change this text
hmmmm, Whats wrong with the STOCK one?
Old May 5, 2007 | 08:51 PM
You have the only factory freak 4l60 in the history of GM
Old May 5, 2007 | 10:00 PM
kbracing96's Avatar
Tell me about it, I keep waiting for it to break and nothing I'm not exactly easy on it either,
I think you guys just can't drive
