Stainless Steel Braided Hose for Transmission Lines?
Old 08-24-2007, 12:41 AM
TurboJohn6's Avatar
Default Stainless Steel Braided Hose for Transmission Lines?
I know I read here that someone had replaced their transmission cooler lines with stainless steel braided hose. I would like to know what I will need to do this to my truck. What length and size hose? What fittings will I need? Any help would be appreciated.
Old 08-24-2007, 01:20 AM
IMD
Banned
IMD's Avatar
expensive....and pointless... why do you need/want to do this?
Old 08-24-2007, 07:52 AM
ScojoDak's Avatar
Not that turbojohn needs defending, but I'm compelled to comment.
Expensive? Perhaps to you. Cost doesn't matter when trickin your ride.
Pointless? Not to me!
Why? Because I installed a tranny cooler and like the braided line look.
Why did I? Fit, Form & Function.
IMD, if I may comment on your post, it's pointless and I dont know why it it's your concern on why we do it! Do you have a positive comment on the question? Have a good day!
Old 08-24-2007, 07:57 AM
ScojoDak's Avatar
Turbo, there are various adaptor fittings available to run the line. On my 99 Dakota, I'm using -6an line because I recently intalled a tranny cooler. Total cost was about $50/$75 after all was said and done. May I suggest you carefully plan or you'll have a stockpile of fittings and hose laying around. Good luck with the install.
Old 08-24-2007, 11:18 AM
Banned
litreddevil's Avatar
i am doing the same thing when,all said and done
Old 08-24-2007, 12:37 PM
formerly 1BADC10 (12/14/2011)
95ImpSS's Avatar
Thought one should add that the total cost to replace ALL trans lines with stock lines cost ~$75 (think braided would be ~25% less, total). So, there's no cost difference b/t stock and braided lines. If I had known this prior to doing my swap, I'd have gone to braided lines instead of stock ones... for the custom look, and ease of routing in any vehicle. I realize that IMD may have been pointing out on one side, why spend the money... too expensive. It's not really THAT expensive to do (if you have the means to support it).
Great choice!
GXPJAY
02-13-2022 08:15 AM
FlowmasterMufflers
08-17-2015 04:44 PM
thewrx
08-12-2015 08:28 PM
carid
07-24-2015 05:00 AM
Quick Reply: Stainless Steel Braided Hose for Transmission Lines?
