spray/4l60e confirmation
Old Nov 14, 2013 | 11:26 AM
James B.'s Avatar
Thought of something else... might be able to wire a relay into the tow/haul circuit that connects with the nitrous solenoid. Adjust the line pressures of the tow/haul tables. Can't say I've seen anyone do it but might be worth looking into.
Old Nov 25, 2013 | 05:53 PM
Blwn99x's Avatar
my "tow/haul" button is now the "performance" setting and the trans shifts more aggressively,higher line pressure,etc.this would be good for when you want hit the NAAAAWWWS,i mean nitrous . of course you can tune the trans for nitrous also.talk with your tuner about this, or i can direct you to mine
Old Nov 25, 2013 | 08:20 PM
apex2112's Avatar
along with a shift kit and corvette servo you could also add the Sonnax heavy duty 2-3 shift valve Sonnax - Aftermarket replacement transmission, torque converter, and high performance automotive parts
With that valve when you are in D3 it applies the overrun clutches in 1st, 2nd, and 3rd gear where the oem valve only applies the overrun in 3rd
ARC
57
Feb 21, 2022 10:54 AM
lucas287
31
Jan 12, 2021 06:18 AM
muncie21
Sep 7, 2015 09:55 PM
LSX-81-SIERRA
Sep 5, 2015 02:51 PM
