speed engineering 4l80e lowered crossmember
Old Oct 2, 2006 | 12:03 PM
adam1803's Avatar
Default speed engineering 4l80e lowered crossmember
Do any of you guys have pics of it installed? I was under the impression that it was a bolt on piece but just found out that there is cutting and welding involved that i really dont want to do, especially for a piece that cost almost 3 bills. Does anyone know if the regular crossmember they sell bolt on?
Old Oct 2, 2006 | 12:46 PM
02BlueStepside's Avatar
By lowered, do you mean a section crossmember so it doesn't hang lower? If so, you should have to cut the crossmember, just the mounting points where they hang below the frame. A lot of guys on gmfullsize are running sectioned crossmembers for the stock 4l60, I would assume its about the same as the 80e. You can check there for some installed pics though.
Old Oct 2, 2006 | 04:10 PM
adam1803's Avatar
its a crossmember that they make specifically for the 4l80e conversion on lowered trucks. Im either going to cut up my stock one and use that or send this one back for a standard crossmember if it is a bolt on piece. Im definetly not cutting up and welding this one.
Old Oct 2, 2006 | 10:02 PM
Yeah, speed eng. makes a crossmember for lowered trucks. Sorry, no pics.
Old Oct 2, 2006 | 10:53 PM
Scream's Avatar
MOOBIES Moderator
I have the crossmember on my truck (no pics unfortunately) but in order to make it a true lowered crossmember, you're going to have to cut out some stuff. It's nothing major, but if I recall correctly there isn't a true bolt in lowered crossmember b/c of the way the stock mounts dip down from the frame. It wasn't a hard install, and it took the shop that I had do the work no time at all to get it in. I would stick with it as it's a nice piece and worth the fab work for the install.
Bumpers
Aug 4, 2024 09:44 PM
5.3Okasai
Mar 9, 2022 01:07 PM
Ferocity02
Jan 23, 2016 06:43 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
black6spdz
Jul 16, 2015 01:32 AM
